shiny seams
7 May 2009
Yorkshire
Just finished a papering job for friend of a friend.All well till today when called for payment.With the daylight on the walls at a certain angle all of the seams look shiny.
I have been decorating for a few years and never had this problem before.I don't think it is paste as I wiped over after every drop.When I wiped over I didn't use excessive pressure on the sponge.Any idea's why it is shiny and more importantly any idea's of how to remedy it.
Laura Ashley paper.....washable
cheers Elk(newbie)
Sounds like you havnt done anything wrong then..have you tried wiping the same sponge and water down a seperate of the paper?..if the sponge has caused the damage it will mark the paper wherever you have used it.
Did you sponge the points straight away pr ;eave them till the end?..it culd be dry paste
Failing that...faulty paper, caused when the rollers are misaligned during production.
Hnag another couple of bits...but dont touch the joints whatsoever..other then when your tapping the seams togther
Where the seams were wiped, it is the diluted paste has sealed the paper. It does look awful and is annoying.
Personally i would use a good cotton cloth in hot water and not a sponge and rinse out every drop of paste on each length of paper. It will only be dilute paste coming out of the edges.
Yep...
And thats got me thinking, if it was a new sponge they sometimes have a yellowy oily dye come out of them
Also, when pasting, a small amount of paste, never matter how small, does get onto the surface of the covering when pasting near the edges, which when wiped, even with a damp clot/sponge, gets diluted and spreads.
What we have suggested are preventions. The cure, there does not seem to be one.
