- Joined
- 21 Jun 2005
- Messages
- 2
- Reaction score
- 0
- Country
In process of have new bathroom fitted; have a few issues with the quality of workmanship from plumber.
1. SHOWER. I have a 900mm, curved edged shower tray. Plumber has NOT inset tray into the wall nor raised tray from floor. (a) should I insist he does? I\\\'I'm concerned about relying on sealant alone to make shower cubicle watertight (b) waste water from separate bath is refluxing back into shower tray, pipes joined at connector, is this resolved easily?
2. BATH. Removal of old bath left a 3cm gap in wall. Plumber did not plaster over gap. Rim of new bath rests at same height as gap in wall i.e. bath not resting against wall. Should I insist that gap is plastered over to minimise movement when using bath? A frame will be built for panels - will this reduce movement? I\\\'m concerned movement will affect tiling on wall.
