Hi everyone,
I had my roof reshingled last year in Michigan and now have a leak (may have been leaking a while) coming into the attic against the visible masonry on the corner of chimney.....it also has siding on the roof around the chimney.......
My question is, should the roofer have changed the flashing to the chimney as part of the reroof or at least took responsibility for it?
The reason I say this is that I believe that the siding should not play a part in the waterproofing of the roof (correct me if I'm wrong).
The roofer is saying that the leak could be due to the cement cap, flashing or siding.......Its not the cement cap because the water is not penetrating into the chimney and also has a large galvanized cover, also I believe that the siding should not play a part in the waterproofing of the roof really, (correct me if I'm wrong)....
Also what guarantee is pretty much standard for a reroof?
Should I accept a leak from around the chimney after a reroof?
Love to hear anyones views,
Many thanks
Many thanks
