Hi all. Quick question and probably an easy one for you guys to answer.
I've got a new shed in my back garden and I've only recently noticed that the roof is not fixed down to the rafters at all as far as I can see. I can push the roof up a bit in the middle above all three rafters so it is definitely not fixed to them.
On further inspection it appears also that the roof is only fixed down to the shed in maybe 5 or 6 places in total. In one section along the eaves I can push the roof up around 1" and there is definitely no fixing in that section for around 9 feet and similar on the other side. The 3 corners feel solid as in I can't lift them (although they are a tight fit) but 1 corner of the roof I can lift a bit so no fixing?
It's an apex shed and is around 18' x 8'. It has torch on felt on the roof and is tongue + groove.
My question is, is this normal to not put many fixings in so that the roof has movement when it gets hot or could it potentially blow off in a gale?
I've tried to speak to the company a few times and someone keeps telling me they will get back to me but so far nothing.
Cheers.
Cheers.
