Should I block a hole on a wall under a bath or leave it for ventilation?
11 Oct 2016
There are a couple of holes each the size of half a brick in the inner brickwork under my bath which is on the 2nd floor.
Should I block or leave them for ventilation?
I suppose if I have cavity insulation fitted it could cause a problem?
I would block them myself, bit of ready mix mortar in a small bag from DIY store.
In fact I used bubble wrap foil insulation on the outside walls under the bath as well.
100mm of it? A single layer would be largely ineffective.
Fill the entire space under the bath with it, keep the water warmer longer
Block them up. Ventilating cavity wall insulation reduces its effectiveness
Better than nowt! (y) I hate it when people stuff the entire space with itchy fiberglass then muggins has to work under there!:mad:
i would say anything thats not expected is always better brought to standard
yes it may ventilate but as its hidden it can cause all sorts off problems as its unexpected--- it can also send moisture in a hidden way to where it can do enormous damage unseen or known but source unfound because off non-standard construction or choice off unusual routing
much better to do things the normal 'more predictable way as it simplifies everything from fault-finding to predicting whats needed to get a known outcome ----
--- and as woody says fire spread via an unknown rout or passage
