Should I fit wall ties in the top coarse? Cavity is wide.
11 Oct 2016
Hi, I need to retro fit wall ties, do I fit them in the top coarse?
As well as the others?
Also it's been done incorrectly before I think they were too short (the cavity is around 150mm at the bowing part) and some of them went into the mortar.
In order to re use the outer holes is it possible to re drill at an angle to hit brick instead?
