Should I get render removed down to floor?
JP_
17 May 2012
Have had pebble dash removed, to be replaced with a silicon render.
1930s solid 9 inch brick walls. Damp course above air brick.
Should I get this black-painted render removed all the way around too - is this a bridge over damp course risk?
If I do, what do I replace with?
Yeah, there has, but all air bricks were blocked up, and most problems on the side that had a concrete path raised up to damp course too, now removed.
Has the damp shown any signs of drying out since these were removed?
If you remove the lower render, you don't need to replace it at all. Assuming the brickwork behind is in good/decent condition, simply clean them up and have them on show. It may be advisable to put a bell casting on the bottom of the upper render to take any water drips away from the lower brickwork faces. And you might possibly have to do some re-pointing to the lower brickwork, but at least you won't be bridging the DPC.
The renderer said he was putting something on to stop water dripping down, so possibly bell casting.
Guessing the brickwork will look a bit rough. Doesn't worry me, but my wife might disagree!
