Hi all
I’ve got an unvented hot water cylinder in my house with a 3 bar pressure reducing valve on its inlet.
In my bathroom I’ve got a 3 outlet thermostatic shower mixer valve, which is fed from the hot water cylinder and the cold mains.
The water from the shower mixer tends to stay cold / luke warm, unless the temper control is turned almost all the way towards hot.
I’m thinking the mains cold might be overpowering the flow from the cylinder due to the pressure difference.
I have tested my mains pressure using a gauge on an external garden tap and seemed to get around 4 bar.
So if the cold mains is around 4 bar and the hot cylinder is being reduced to 3 bar, would adding another 3 bar pressure reducing valve on the cold mains (somewhere before the shower mixer) make any difference to how the shower valve is operating or is the difference between 3 and 4 bar negligible?
