should I put lining paper on newly skimmed plater?
9 Sep 2015
Ive just have my plasterboard walls skimmed and I now want to will wall paper the room
what is the standard method
mist coat wall them wall paper
mist coat then lining paper then wall paper
cheers
jon
No.
It should be smooth and flat and not need lining paper. If it is just a skim it should dry very quickly.
Some people (incl me) prefer to emulsion the walls (one or two diluted mist coats with a brush, then undiluted with a roller) which will look decent until you get round to papering, and IMO gives good slip which makes it easier to paper, needing no sizing, and makes it easier to strip and clean in future. If it is just a skim you can use a vinyl emulsion. It will also highlight to the eye any defects, which you can fix if you desire perfection. The paint will also give the walls an even colour and texture, which will avoid shading showing through (this is more valuable on patchy old walls).
If you are in a hurry, or a pro and time is money, just paper it.
Thank you so much ...its so nice when some one gives a clear and simple answer
