Hi, I am just replacing our kitchen electric hob with a new Samsung C61R2AEE.
The hob I have removed was bolted securely in to the work surface with two brackets from below, but this new unit does not appear to bolt in place. There are two rails that are secured to either side of the hole in the work surface and the hob has two lugs each side which slot in to the rails. However the hob appears to just sit on the brackets rather than being bolted in securely.
Is this normal for new modern hobs. I guess it is heavy enough not to move and could just be lifted out to clean under if required, but should I seal around the outer edge (above the work surface) with clear sealant or something (the manual seems to advise against this).
Thank you for any advice.
