Should you compress glasswool insulation?
28 Mar 2016
I have 160mm joists in my loft floor.
It appears you can't buy 160mm depth glasswool insulation. So should I insulate with 150mm glasswool and have a gap, or 170mm glasswool and compress it slightly?
I've read compressing can reduce insulation's performance, but would it be below that of the 150mm option?
Which is the most efficient option? Pricing appears to be the same for each.
use 150mm
the cumulative improvement of another 10mm is imperceptible
the 170mm rolls are shorter
10mm will probably also be imperceptible.
Generally, compressing insulation brings no benefits, and brings the risk of making the ceiling bulge.
