I've got a Nabis d12091 shower pump, and I've discovered a leak on the hot output. Before I take it apart and put it back together, I assume that his will be a seal by washer, rather than by threaded connection.
If so, is there any particular washer I should be using for the connector?
Last but not least, as there's no isolator, I would be correct in assuming that it's safe to remove the hose with the water on (it's the output)?
