I have replaced an existing basic 'Mira' mixer shower with a temperature regulated twin tap valve. Possibl related I also fitted a new basin. The shower is fed from the existing 15mm pipes that fed the old shower. Having fitted it I turned on the tap and nothing happened. Neither hot nor cold. However when the hot tap in the basin is turn on then off the shower (hot) starts allbeit with a pitiful flow rate. Cold seems to work sometimes again poor flow. I measured 4 pints a minute! Theres only about a metre or so of head below the cold storage tank so pressures not going to be great but I assume I have an air lock. Can it be solved by using mains presure to blow back into the tank? There are non return valves that would need removing from the shower unit. Any comments would be appreciated. Matt
