Shower base removal
16 Apr 2006
I am trying to remove a shower base in order to replace it with a new one. The old base is 20 years old. I am having difficulty figuring out how to remove the top of the drain that sticks out over the base hole so I can remove the base. Any information on this would be appreciated. Thanks.
Roget
You have not specied what your base is made of!
If its steel or fibreglass you could cut a hole near the waste to see how to disconnect it ( by using an angle grinder ).
Tony
PS Can I borrow your thesaurus?
Thanks for your reply.It appears that it is a white plastic base being held by a black PVC screw in pipe with a flange that screws into a drain pipe that has outer threads. It is a flat circle but has nothing to grasp onto.
Some types can be unscrewed from the top using the "drain holes" with a specially made up tool.
However the usual arrangement is just like any sink or basin waste that its just held on with a nut from underneath.
Tony
Thanks for all the info, Tony. Looks like we will have to take a sawsall to the base and see which way it is attached. Appreciate your help.
Roget
It's possible that your shower waste is like the modern ones, i.e. there is no screw like on a bath waste.
The McAlpine traps have, as do many others, a removable 'grid', and from underneath this you can then remove the centre part of the trap.
If you replace the 'grid' then the part that you removed inverts and becomes a tool with which you can unscrew the flange from the trap base.
