I have just moved into a 1 bedroom 1st floor flat with only a bath.
I want to put in a shower early next year. As a short term soloution I put a tap mixing attachement on the taps ( http://www.argos.co.uk/static/Product/partNumber/8323703/Trail/searchtext>SHOWER.htm ) until I can afford to put the shower in. There problem is with this is that the cold water pressure is so bad when you lift the shower mixing tap attachment above tap level hardly any cold water gets out the attachement. Hot water is fine but it is too hot because there is not enough cold mixing in. The cold water tap works fine without attachement.
I have a combi boiler (Wrosester 28Si II) and also what looks like a big black water tank in the hall - would that be for the cold water or hot?
How can I solve this cold water problem and what type of shower would you recomend for this type of setup?
Thanks for any help / advice.
