Shower booster pump
The distribution pipe comes out of the top of the cylinder, turns right horizontally. It then goes into a Tee ,going up is the vent pipe,going downwards from the Tee towards taps is where to fit the pump. Fit it at least 400mm from the Tee.
Hi, moving out is not an option but understand your point. When all said and done, this is something that needs doing. Given the amount of pics i have sent, would you be able to simply circle where you would fit the SP1. Thanks as always.
