Hi all.
I was looking into what size cable needed for a 9.5kwh shower and the general consensus is to use 10.0
Having read why with regards to voltage drop, is it mainly down to if the cable is insulated anywhere?
(and the length of run)
My set up will be from CU, under floorboard cable will be sitting on the dirt/rammel that is under there, there is crawling space.
Then up and around a door in the under stairs cupboard in plastic trunking.
Then between ceiling and bathroom floorboard with no insulation,
Then up behind stud wall to loft, into pull cord switch and back down to shower unit.
Total run is 13/15 metres.
I've found a couple of calc's that suggest 6.0mm would be okay.
What are anyone's thoughts?
Apart from the 'If you need to ask you shouldn't be doing it' and the 'call an electrition' and the 'This work is notifiable'
Cheers
Cheers
