Shower cable routing
7 Jul 2006
Lincolnshire
With all the regs on shower cable runs, is it possible to run a 10mm cable out of the the consumer unit and straight up the outside wall, into the loft, along the joists to the switch. The cable will then have a 1.2m run inside 'straw' insulated plasterboard to the shower unit. :?:
The same as they are for any fixed cabling
Only if the cable is of a type ythats not harmed by the UV in sunlight
Make sure you provide suitable cable support, you can't just lay it across the joists
This will be where the cable has its lowest current carrying capacity, ensure you select the correct installation method when calculating the capacity of your cable
Are you aware of part P of thge building regulations, I trust you are planning on notifying this work to your local building control office?
Thanks for the advice Adam, yes all the work will be checked by the right bods etc. I was just wondering about my options as I have a gravity feed shower which is very old, I have repaired it with seal kits, knobs etc too many times now - its getting boring!!!
Cheers
You need a thicker cable on verticals to offset the natural tendency of gravity in opposing the flow of electric uphill.
And make cabl runs smooth because showers don`t work well with knotted electric and the water comes out lumpy
:LOL: :LOL: :LOL: :LOL: this had be in stitches thanks!!! :LOL: :LOL: :LOL:
<imagines lumpy water> :LOL: :LOL: :LOL: :LOL:
