My ensuite bathroom has a very elderly 8.5kW shower that I want to replace. Flow rate is generally poor despite excellent water pressure to the house, temperature adjustment is usually either "too cold" or "too hot" and if water is drawn anywhere else in the house (e.g. flushing a toilet) when using the shower it scalds you. Not good.
I recently fitted a Mira Sport Boost shower to the main bathroom and really like it - the air boost feature makes it feel much more powerful and it's pretty good at maintaining a constant temperature. I have the more powerful 10.8kW version but I see there is also a 9KW version. On the maximum power setting I never turn the temperature setting more than halfway as it's plenty hot enough.
Going back to the ensuite bathroom, the existing shower is supplied by a 6mm cable. As this is only visible at the consumer unit I have to assume it's buried in the wall and don't know if it's in a conduit or just covered in plaster. The consumer unit is at ceiling level in the room below, almost directly underneath the shower, and the cable goes up to the pull cord isolation switch in the ceiling above the shower before coming back down again into the shower. I doubt the total cable length from consumer unit to shower is longer than five or six metres.
I got in an electrician to look at the type of cable and he said I should be looking for showers up to 8.7kW. At the time I hadn't seen the Mira came in a 9kW version so I would like to know how much difference there is between 8.7 and 9kW over a fairly short 6mm cable? Initial Googling suggests lots of people asking about the maximum rated shower that can run on a 6mm cable; some responses say even more than 9kW is OK if the cable is short (define short?), others that even 8.5kW is too heavy a load for a 6mm cable. How do you determine the maximum power rating that a given cable can safely deliver?
Unfortunately the "obvious" solution of swapping over the cable for one that's 10mm is simply not an option as it would involve having to totally strip the bathroom and get laminate flooring up in two rooms.
If a 9kW shower isn't an option, can anyone suggest a lower rated shower that would be acceptable (constant temperature, and ideally have a similar feature to the Mira Airboost)? I don't want to simply replace my existing elderly cr@ppy 8.5kW shower with an equally cr@ppy new 8.5kW shower.....
