i have got a new team shower with a pump and a normal hot water tank with header tank,obviously we run out of hot water after a while and would like constant hot water, i would like to have a combi boiler but can't pump the water twice, can you suggest anything.[/b]
I am not a plumber or heating engineer, but with a combi you can leave the shower on for as long as you like and it never gets cold (unless some one flushes the toilet)
so if you were to have a combi you could do away with your "power shower pump" and your hot water cylinder
I forgot to mention that a combi heats the water directly as it comes in at mains pressure, so a 2nd pump is not required.
