Hello!
I am in the midst of ripping out our old ensuite and notice that the shower waste pipe connects into the horizontal soil pipe on the side, not the top.
The horizontal pipe sequence is: WC (at the end), washbasin (top entry), shower (side entry) then connection to vertical pipe with vent rising on the bend. The vent is about a metre from floor level. All pipework is inside the house
Our old shower was raised up above the floor on legs, but our new one will be flushed into the floor.
I am concerned of WC waste water entering the shower tray (and to be honest I'm surprised it hasn't happened before). There is not enough room to move the connection to a top mount.
Will a non-return valve be sufficient to prevent this or will I need to run a separate horizontal for the shower and connect this into the vertical part of the soil pipe? As the soil pipe is already vented, will I need a further vent for the shower?
As much as it would be a bit of a faff, running a 40mm pipe into the vertical would not be a major hassle.
Thank you for reading this!
