Updating my previous post:
Here are some pictures to show the problem.
I have a shower tray thats ideally going to be level to the floor. I cannot find a qquadrant plinth kit for the MIRA shower. Its because the tray is a quadrant.
I hoped someone might have had the same problem and found a way around it. I am trying to avoid mounting the trap too low (I cant put it below the soil pipes top level). I do have to go low though as the shower tray will be at floor level.
Here is the en-suite room in the picture showing the layout
Here you can see the old trap and the new trap (in its packet) and the soil pipe in the floor. You can see I have 15mm copper pipes in the floor that will stop the trap just dropping down nicely. Even if it could do that, I don't think I could get a joint in (with top of the trap at floor level) and connect to the existing boss thats shown with the old trap and waste going into it.
The old shower had a plinth so the old trap and waste are all setup for a height thats above the floor level. I need to go under the floor, but it looks like I cant then get the clearance on the soil pipe ?
Would it be possible to run along parallel and breach the pipe later on somewhere ? How do I block the old boss up ? Any other idea. THe cleanest way would be to have no plinth and the tray at floor level. This means putting the trap under the floor. I could do this just with bending the pipes about. Then I have to find an exit for the waste from the trap. The existing soil pipe takes up the whole of the under floor space, is there another way to get the waste out ?
Also is there perhaps a slimline trap of some sort. I have a little bit of space to play with and can cut different parts of the floor out.
I just want as easy a time as possible installing it. I don't want to find that in a months time soil from the toilet next to the shower floods up the waste into the shower. Thats what worries me about going too low on the pipe.
Any ideas anyone for this dilemma.
Howard
TX
Howard
Howard
TX
Howard
