shower enclosure door,replacement.
  • Thread starter rules&rulers
  • Start date
R
rules&rulers
Hi all,
The sliding door in my shower is damaged,one of the bottom wheel roller's has parted company with the glass door,the glass door is actually snapped where the wheel is attached to the glass door,its where the glass door has a hole drilled to fix the sliding wheel/roller.
The make is Victoria L2-E. Roca.
This is now not made,being 12 years old and just looking to find out if there is a secondhand stockist of old stock or preloved shower enclosures.
Thanks for your time.
You're basically ballcocked here.
Best bet is to remove old door and frame and replace new.
Removing frame without destroying tiles requires luck, cheesewire, craft- knife and persistence.
Thank you both for the replies, the cheese wire is something I would have never thought of,it will go a long way to preserve the dodgy tiles on plasterboard.
