Hi, apologies if this is the wrong section.
I'm in a bit of a pickle, our shower has started leaking, a lot, and it looks like there had been a small leak for a while that soaked through the grout (or round it) and destroyed the plasterboard behind it, this in turn allowed movement which made cracks in the grout and even more moisture going into the plasterboard, more movement etc etc... I only actually realised when I noticed water leaking from the ceiling below so it had got quite bad at that point.
I pulled the plastic surround away from the shower tray and poked a finger into the plasterboard whereby handfuls of wet plasterboard were just falling away... Yay!
So... What do I do now?!
I know I need to remove the enclosure, pull off some (all) of the tiles from the rotten plasterboard and replace said plasterboard with new.
However, I've read that you shouldn't be using plasterboard and that it should be ply behind shower enclosures? If this is the case do I need to strip the tiles all the way up replace the entire plasterboard wall behind the shower enclosure with ply?
Or what?!
Really just looking for advice on what the heck to do!
Cheers, Rob
Or what?!
Cheers, Rob
