shower enclosure
27 Jan 2014
Essex
I have fitted a shower enclosure this week that a customer purchased in a sale I am led to believe. Square enclosure with pivot door.
Very cheap standard. Under the fixed side, the enclosure sat about 1omm off the tray where the two ends were manufacture lower than the glass panel, if that makes sense.
Also the door does not open and shut freely, you have to force it upwards when closing to shut it. The seal at the bottom off the door is catching and don't help its made out of very hard plastic. The door is factory manufactured into the frame and there seems to be no adjustment???
Everything is completely level, which would not matter to much anyway as the door sits in the frame which should open and shut regardless.
Anyone had a poorly manufactured enclosure before? You can visually see that the door sits wonky in the frame
