Hi ... hopefully this is an easy one.
I have a shower extractor with 12v light fitting above the shower. The bulb recently went so I replaced it, but the replacement didn’t work (I assume the bulb is okay). I tried to get a multimeter to test and appeared to get no voltage but it was tricky to get the probes parallel into the holes so I’m not 100% if it was an accurate reading.
so...now I need to try something different. Is the best bet to replace the transformer? If this is the case how would I get to it? Is it a case of crawling through the loft space or am I likely to gain access through the extractor hole? Loft access isn’t easy so if I’m wondering if there’s something else to try first. I suppose I should check whether there’s something else I should check before the transformer too?
pic attached for reference - I didn’t install it so I’m unsure of the brand.
thanks in advance!
thanks in advance!
