The shower I am interested in buying has the following spec:
# Thermostatic shower mixer 3/4 inch wall mounted
# GROHE TurboStat compact cartridge with wax thermoelement
# Integrated mixed water shut off
# GROHE SafeStop safety stop at 38degC
# Shower bottom outlet 1/2 Inch
I basically have two 15mm pipes sticking out of the wall fed from the cold water tank and hot water tank, so I assume this one is out as it says 3/4 inch which is 22mm or near enough?
Shall I try and swap the pipes for larger ( I would rather not) or shall I get another type of shower?
Any help appreciated! I need to make a decision!
