I have a new shower that asked for a 15mm brass compression how ever I went to b&q and the plumber said go for the the pushfit as its quick and easy . Anyway my question is do I need to use the brass compression if so will this be ok to be used on plastic pipe?
You can use push fit plumbing for joints , except the final connection onto the shower inlet which must be 15 mm compression to ensure water tight connection.
As you've done it and it's watertight I wouldn't worry too much about it, it won't affect water flow.
One reason to do it as the manu's say is to give them no 'get outs' in case of future warranty problems.
