Hi there, advice & opinions much appreciated please!
My 9kw Mira Sport suddenly stopped working...
Chief symptom is the power indicator light does not come on. Curious other symptom is that the red indicator light in the ceiling switch does come on as normal, but if you press the on/off button on the shower unit, the celing switch indicator light goes off, if you then switch the shower unit on/off switch back to off, hey presto, ceiling switch light comes back on.
I'm suspecting the internal fuse has blown and wonder whether it's worth replacing it before going the whole hog & splashing out (no pun intended honest ) on a new shower. Is it worth it? If so, can someone advise what type of fuse I need, according to the booklet it's 40amp but I'm guessing when I walk in the hardware shop I need more information that just "a 40amp fuse please" - ? Also, should I be deterred by the manufacturer's warnings about 'no user-servicable parts... you have no business opening this cover...' or is it fairly easy to do?
Cheers!
Cheers!
