shower has no water feed.
16 Feb 2006
Staffordshire
shower has no water feed with the low pressure warning light on could this be a pressure switch fault?,control board?,any ideas please name of shower new deal 7.5kw.
Assuming that the water is able to flow as far as the shower inlet, the most likely cause of low pressure is a blocked inlet filter.
cheers chris will check inlet filter to see if blocked but was not sure if could be an electrical fault?
