Hi all
I recentley purchased this from B&Q
http://www.diy.com/diy/jsp/bq/nav.j...efview=lister&ts=1268074399600&isSearch=false
However it does not come with any fixings for the shower head (to fix to wall ) or conections to connect to 15mm copper pipe ( tap connector?).
Whats the best way to achieve this?
Also the mixer just has female threads, i assume i can get something from plumb merchants to get this to connect to my existing 15mm copper pipes?
Also while I'm at it should i make improvents like 1 way valve on cold pipe or just leave it as is?. I mention this as it goes on about shower head sucking water back in or something along those lines.!
Thanks for any help on the matter
