Other than ensuring the shower tray is higher than the waste outlet, is there any other way for me to disperse of waste water from the shower?
I would like to keep the shower tray to a minimum height.
If you have floorboards and a void or airspace below then you can cut a hole into the floor for your waste trap and pipework to sit into and then run your waste pipes to your outlet but you will be governed by the height of your external drain so check it's position first.
