if your existing shower has 6mm cable and you have just run in a 10mm cable then providing the jb is suitably rated then yes you can.
HOWEVER if your shower has 10mm cable and you want to join it to a 6mm cable then this implies the shower needs a 10mm cable, so no you can not. because the 6mm cable will not be able to carry the amount of current required safley.
