shower light & fan position
12 Aug 2010
Merseyside
Hi is there a right place to fit a shower light extractor in a 1200 x 900 shower cubicle should it be in the centre or to one side of the cubicle Many Thanks
it depends.say you go for the central position, put a small pilot hole in and check out the loft area.what will you do if youre close to a joist and cant put it there, what will you do then?
any time i.ve installed them it is a balance between ideal location and looking ok with the other lights in the room and where it will actually fit. only you can judge that, but anywhere in the cubicle area and it will do the job
