Hi All
Firstly I would like to thank any one who takes the time to read this and then gives me some ideas.
I have a small one bedroom flat and had a Worcester Combi 24cdi fitted November 2001, all previous
Water storage tanks were removed.
In April 2005 I had a whole new bathroom suite fitted and got the plumber to extend the pipe work from the bath tap outlets up the wall to fit a thermostatically controlled shower mixer bar.
I never tested the shower ( long story ), but rented the flat out in May 2005. The tenant complained that shower wasn’t to hot so I called Worcester Bosch out as I had a service contract with them. Although they had already replaced several bits in Nov 2004 including the heat exchanger they replaced something else and I never heard from the tenant again about the problem.
New tenant moved in last month and complained of the same problem, shower not getting very hot. I still have a service contract with Worcester but now I am thinking that it is the shower not the boiler. I went to check it out for myself , this is what I found:
Plenty of pressure and hot water to kitchen tap
Plenty of pressure and hot water to Bath tap.
Boiler fires up OK when shower mixer turned on, the red light is on all the time.
Boiler is on maximum heat for hot water.
Took the end of the shower mixer bar apart as the red knob which prevents going over 38c was stuck down.
Manually turned the brass swindle with my fingers on the temperature end of the bar that I had just taken apart
Didn’t matter how far I turned it up the water was still luke warm.
I could feel the hot water pipe on the wall coming into the mixer bar was hot, but the mixer valve isn’t doing a very good job of mixing the water.
The cold water pressure is very high from the shower head and I am wondering if this is over riding the pressure of the hot water.
Or maybe it is just that this mixer bar was a cheap low quality model that I got from Ebay, it was new though.
I have found a very similar looking model and price currently on Ebay, not sure if I am aloud to do links to other sites but not sure
How to up load a picture, thought it would help if you could see a picture of what I am talking about.
http://cgi.ebay.co.uk/SAVES-ENERGY-...ryZ42347QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have read and searched this forum for other posts on this subject before boring you all again, but was unable to get any sound advise on whether you can use these thermostat controlled mixer bars with a Combi boiler
Ok so do I replace the mixer bar with another better quality one, or forget the thermostat controlled bar and fit two separate knobs so the hot and cold can be mixed manually by a human being.
I think this shower as been like this since the day it was fitted and the previuos tenant just lived with the luke water.
All your help would be appreciated as I can do this job myself OK, just need to fit the right one this time.
Thank You
Julea Field
Thank You
Julea Field
