- Joined
- 2 Mar 2006
- Messages
- 52
- Reaction score
- 2
- Country
Bathroom was new installation 18 months ago with a separate Crosswater shower unit with thermostatic mixer and a separate bath running off a combi boiler. The shower was taking longer to heat up. Had the boiler checked out and the engineer said it will take longer as it's cold in winter. However also noticed the temperature of the bath hot water if affected by the position of the shower valve. When the shower valve is set to cool ( and not even running) the bath hot temperature is significantly less than when the shower valve is set to max. Boiler engineer suggested their might be something to do with the the pipework to shower/bath. Can't access any pipework as it's now all tiled. Any ideas on a fix ?
