As part of my first bathroom renovation, I am planning to install a new shower with a bar mixer above the bath, with pipes going up from under the bath behind the wall to the mixer. Here's what the pipework to the current bath tap looks like:
For both the hot and cold pipes, I think I'll need to cut off the old pipework just above the floor, put in a combined check/isolation-valve, and then a T-joint to which I can then re-connect the tap, and have a pipe going up the wall to the new mixer.
To get the pipes for the mixer behind the wall, I'm planning to remove the dot-n-dab plasterboard behind the bath, batten out the wall by 2-3cm, and replace with cementboard, giving just enough room for the 15mm pipe and clips.
Does this sound like a reasonable plan? I am still quite new to DIY, and this will be my first plumbing project, so any help would be greatly appreciated!
Cheers
Cheers
