Hi all,
There are numerous posts on this topic but having read them, I'm still not 100% clear on the correct way to approach this specific job. I want to install a shower mixer bar on an internal breeze block wall. I plan to use copper pipes with a soldered elbow joint and would like to get some advice on burying the chased pipes.
I had planned to clip the pipes to the wall and then just cover the pipes (and clip therefore) with polyfilla or something of this nature - maybe patching plaster? Then I will tile over them as normal.
I think this should hold the pipe nice and firm in the wall so it doesn't rattle however how worried should I be about expansion / shrinkage due to temperature changes? I assume this could crack the plaster and weaken the structure? Also, as I will be using plaster/filla I wasn't planning on coating the pipes - not sure if this is OK? I won't be able to properly pressure test the join but will run mains pressure through it before patching up to ensure it doesn't leak.
Any help would be much appreciated! I know similar posts have been logged before but many focus on insulation due to external walls.
Thanks,
James.
Thanks,
James.
