Hi All,
I've just fitted a 8.5Kw shower to replace an old one which I should have tried before scrapping it, at least then I'd know if the new shower is at fault or not. The pressure is really feeble. The shower also shuts off its heating element if you turn it above about 3 (the pressure drops as you turn it up as I'd expect). Its T'd into the cold water feed for the hot water tank in the loft which as far as I'm aware is at mains pressure. The baths cold water tap appears to have plenty of pressure.
Has anyone got any trouble shooting advice ?
Does the shower shutting off imply that its not getting enough pressure or an internal fault/blockage ?
I can't remember the make or model, I can look that up and add it tomorrow. Unfortunatly my laptops just died so I cn only get on here at work.
Allan
Allan
