Shower neon indicator light not working
8 Mar 2005
Just replaced a shower everything working as it should except that the neon indicator light does not come on when the shower is working. It is giving me hot water, its not on the cold water setting, and the pressure seems ok. Is this a wiring problem or is the neon bust...should I stop using the shower??
Bear with me as i am not actually in your bathroom.
When you say "neon indicator light", which one do you mean???
On the shower unit?
on the isolating switch?
on the wall?
some other place?
Sometimes the neon comes out of the window housing, giving the
impression it is not lit,
when it is, but hanging loose inside.
it is the neon indicator on the shower...I will check that it hasn't come out of its housing...just worrying that it may indicate that the shower hasn't been properly wired up....
problem solved.... light now working wasn't 'clipped' into place...thanks
