In the middle of a shower the other day, one of the switches tripped in the fuse box and when I turned it back on, the shower was quite cold. If I turn the temperature dial all the way to hot then the temperature is almost hot enough, but the pressure is terrible.
I'm far from an electrical expert, but I don't mind getting stuck in and having a go and have had some moderate success in fixing things in the past. After a bit of googling I found this article (http://timwolverson.wordpress.com/2013/09/30/how-an-electric-shower-works-common-electric-shower-faults/) that seems to suggest if there was a problem with one of the pressure switches that one of the heating elements wouldn't work which I assume could be my problem.
I've took the cover off the shower and tested the two terminals I've circled in the image below with a multimeter. I get a beep from the meter when touching the two green terminals, but not the two red terminals. Does this indicate that one of them is broken? If so, which one?
Thanks,
Anthony[/img]
Thanks,
Anthony[/img]
