Shower not hot enough!
9 Nov 2005
I :( 've just moved into a rented property with what looks like a fairly new shower - Galaxy Aqua 3000. However, in order to get a warm shower, I have to have it on setting 10 of 10, thus the pressure is little. Any setting below 10 is just plain cold! Anyone know of a way of increasing the temperature on the lower settings so I get a hot shower with some pressure?! Cheers
It's probably the 8.5kW model,so it will be a little feeble, particularly if your voltage is low.
OOI - is there a discernable difference between the low & high power settings?
There is a fair bit of difference, the settings 1-7 are fairly powerful, but cold. Yet not much power in 8 9 and 10....which you need to have on to get some kind of warm water! There's no settings or valves I can mess around with inside the cover is there?
I don't mean the flow control, i.e. the knob that goes from 1 to 10 - there is another knob that does COLD, LOW & HIGH selection.
the one on the top right.
On any flow setting, is there a difference between low & high?
