Hi there, Ive read through other shower probs posts but didnt find any similar problems.
I have a Mira shower which was installed by the local council approx 4 years ago, however, I now own the property and the shower is not working. I wondered if one of you would possibly be able to assist in ascertaining what the fault may be. So I can decide whether I need an electrician to come out, or if I need a new shower. I've also emailed the manufacturers asking the same question.
The model is Mira Sport 9.0 J92B 13/03
I turned the pull cord on yesterday, which lit up at the top of the pull cord as usual (the red light may have been slightly dimmer than usual), however the 'POWER' neon light did not light up on the unit as it usually does. When I turned the unit on, it did not operate, and the red light at the top of the pull cord went off. Which I am certain does not usually happen when the shower is in operation.
Any advice greatly appreciated. I thought perhaps a fuse has gone in the unit or in the isolator pull cord, but I wouldnt know where to check for this, or could it be a problem with the wiring? Dont want to fork out for a new shower if its something that could be quickly fixed by someone who knows how!
Many thanks
Many thanks
