Hi folks, i have just fitted a creda 550c shower, plumbed it all in connected the electrics but nothing happens, i have checked and there is power to the shower any ideas please
i checked with an electric screw driver that there is power to all parts of the shower,
it does not tell you how to commison it only tells you how to start it.
although there is power to the unit the wall switch light is not on but i think thats onlt the bulb gone
throw the neon screwdriver away. they are useless.
buy a multimeter and test for 230v between live and neutral.
or else call an electrician. You sound out of your depth.
The red light in shower switches dont go out like bulbs. They are permenant, they will last as long as the switch.
You have wired something wrong, or done something wrong.
What cable have you used?
What is the power rating of the shower in watts or kw?
What is the rating of the switch?
What is the rating of the circuit protective device?
Is said circuit RCD protected?
Sounds like it could be a neutral fault. Those neon screwdrivers are useless so get a proper test meter round it to see if you have 230V. I suppose if the screwdriver lights up when placed on the neutral terminal that could indicate a break in the neutral as the lack of potential would cause the neutral to become live as power passes through the internal electrics of the shower. I assume you have no electrical experience?
Looking at it a Creda 550C is a large electric shower (9.5kW+) so you'll need atleast a 10mm cable. Is this a new installation you've carried out or are you swapping out an existing unit. If it's a swap out what was the rating of the existing shower in kilowatts (kW). How big is your supply cable? What sort of consumer unit (fuse board) have you got? What is the rating of the breaker/fuse feeding the shower? Is it on a dedicated circuit?
Need more info then you've already given to give any educated help.
