shower on low cold pressure system
20 Jul 2005
Clwyd
hi
we are planning to install a new shower but have a terrible cold water supply. It's shared with the neighbours so we regularly loose pressure to our supply.
We recently had new central heating & boiler fitted, we couldn't have a combi as pressure was too low so now have boiler with tank above and hot water cylinder for hot water.
Any suggestions as to what may be best solution for shower, would a pump help or would this have problems with dipping cold water supply? or would we be better of with a Venturi shower or would this again have problems with our intermittant cold supply?
any advice appreciated! :D
forgot to mention, cold water supply to bathroom is direct mains,
cheers!
You will need a mixer shower with the cold supply off the tank NOT mains.
Also a pump if flow is poor. :D
if cold supply is off tank why not try the triton t80s1 its a pumped electric shower
