I am coming to the end of a long (since April) bathroom project and my next job is to fit the fixed shower outlet/sprayhead. It is a Triton and the (pretty hopeless) instructions say I should fit the elbow fitting flush with the finished tile surface. I am using 9mm marine ply as the backboard and I have calculated that when allowing for thickness of ply, tile adhesive(6mm when bedded) and tile (8.5mm (400x250 tile)) I will have to have the wall plate elbow protruding 14.5 (15) mm from surface of the ply which means when taking the thickness of the ply into account the female neck of the elbow fitting is not long enough to prevent the pipework restricting from behind the board (hope all this makes sense).
The question I have is , is it possible to buy long neck wall plate elbow fitting ? If so where from ?
Also how critical is it to actually have the fitting flush with the tile surface as Triton reccomend?
I should also have mentioned that the Triton system is for a brass connector to screw into the elbow with the other end sliding into the shower arm, with 2 'o' ring seals.
I have looked on the web for long neck elbow fittings with no luck.
Thanks View media item 23203
