I am going to be creating a shower enclosure with shower panels. They are 10mm PVC, and are tongue and grove between panels and an aluminium corner profile. Under the shower tray will be 18mm marine ply. There will be two panels on one wall, and one on the other, so a single t+g connection, plus the corner profile.
I was originally going to use standard plasterboard for the walls, tanked with Everbuild Aquaseal.
However, I am now considering using 12.5mm Marmox boards for the walls (on battens with 300mm centres, noggins at joins), and also laying Marmox boards on the floor between the tray and the marine ply.
I am just wondering if panels + marmox + tanking + marmox under the tray is overkill, and what the best mix would be.
Any thoughts from you folks would be much appreciated.
