Hi there , was wondering if anyone could shed some light..
Had a 11.5kw shower and started getting a fishy smell from the switch.. On investigating noticed some burning on the neutrals on the cables. One of the neutrals and one of the lives were not tight in the connectors guess this could have caused the issue. But on inspection noticed that the switch was a DP 20amp... Is this man enough for a 11.5 kw shower, was this the cause?
Iam happy with the cable size 15mm and the 50ampMCB . But not sure if the problem was the loose cable or under rated switch. Will get the guy back to fix but interested in the knowledge. cheers
