- Joined
- 12 May 2007
- Messages
- 292
- Reaction score
- 2
- Country
I have a mixer shower off an open vented system, my shower is a Mira fino, I noticed that after running for a little while the pressure drops off a fair bit. If I lower the shower head to the floor I can hear the pressure starting to pick up, I does sound like it is clearing air from the system but not sure if that is correct, if I then put the shower head back on the rail, it will run ok for a while before the pressure then dropping off again, any ideas why this is?, the shower hose does lay on the shower tray, wondered whether I should have kept the mixer higher valve assy higher up the wall so the hose didn't lay on the floor, think air would get out easier then ?, am sure a booster pump would sort it out.
