Shower pressure problem...!
9 Apr 2008
London
Hello all,
My shower seems to have developed a problem last night - it's an Aquatronic 4.
The pressure on the head has gone RIGHT down to little more than a trickle - to co-incide the 'overflow' (?) outlet pipe thing located directly behind where you connect up the shower head is running cold water at quite high pressure! Also, when you first turn it on or off there seems to be a discharge from this 'overflow' pipe that looks like copper / brown in colour and what i can only describe as small pieces of tobacco!? No discharge comes from the shower head itself....the shower runs straight from the external source ie. not the tank.
Has anyone come across this before?
Any advice would be much appreciated!!
Pete
the part you need to replace is 83301330 (part Number) Phone triton they will point you in the right direction as they made it for a Diy Store. got to go fllight to catch.......................
